It is currently Mon Aug 18, 2025 6:05 am
 Post subject: Archtop Pickup
PostPosted: Fri Oct 03, 2014 1:43 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends.
last year i built the guitar to sound like veena.
the customer is very happy with the sound and sustain.
previously he was solo player
now he got invitation to perform with other instruments too.
the problem is that the guitar sound is too low for multiple performers.
so he want to add pickup to it.
may i know which one is best pickup for this type of guitars
as well as how to fit it.
any foto tutorial help will be appreciated
thanks in advance
 Post subject: Re: Archtop Pickup
PostPosted: Fri Oct 03, 2014 5:09 pm
Last Name: Russell
State: Michigan USA
I would look at something like this: ($63.67)
http://www.stewmac.com/Pickups_and_Electronics/Pickups/Archtop_Guitar/Kent_Armstrong_Suspended_Jazz_Humbucker.html
Or this ($141.00)
http://www.stewmac.com/Pickups_and_Electronics/Pickups/Archtop_Guitar/Benedetto_S-6_Suspended_Jazz_Pickup.html
Both attach to the bottom of the fretboard so there is no need to cut the body to install. You may have to drill a hole for the wire and one for the jack but it would be the easiest to install.
Both of these pickups were made just for archtop jazz guitars and would give you the typical sound you would expect from an archtop.
I know there are a lot of others out there but these are easy to install without cutting a hole and retrofitting support braces.
Bob
These users thanked the author RusRob for the post: aqualibguitars (Fri Oct 03, 2014 11:26 pm)
PostPosted: Sat Oct 04, 2014 9:06 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
The suspended style pickups mount to a finger rest. To mount one you first need to install a finger rest. A finger rest is mounted to the fingerboard extension. Kent Armstrong made an archtop pickup that mounted to the end of the neck, but I am not sure if they still make them.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
PostPosted: Sat Oct 04, 2014 9:15 am
Last Name: Russell
State: Michigan USA
Follow the first link I posted... [:Y:]
Bob
These users thanked the author RusRob for the post: Cush (Sat Oct 04, 2014 9:42 am)
PostPosted: Sat Oct 04, 2014 9:40 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Thanks Bob. I missed that link. That Kent Armstrong is a good pickup. And easy to install.
Mark Twain
PostPosted: Sat Oct 04, 2014 1:24 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Country: india
thanks friends for ur replies
is there anything that i can paste on the soundboard and remove it when the player dont need it?
PostPosted: Sat Oct 04, 2014 6:17 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
They do have a pickup that is installed on a pickguard that might work also. You could make it detachable. It has a volume knob on it too. I don't know what its called or who sells it though.
Jason Moe
LaCrosse WI 54601
PostPosted: Sat Oct 04, 2014 8:00 pm
First name: Patrick
Last Name: Hanna
State: Missouri
A pickup suspended from the end of the fingerboard might be easier to remove and hide the remnants of the installation. You'd have four very small holes in the sides of the neck extension to fill and finish. A pickup mounted to the finger rest would be easy to remove, too, but might necessitate making an entirely new finger rest (depending on whether it was scooped out to allow for the pickup body). Still, it would be easy to do.
PostPosted: Sun Oct 05, 2014 8:23 am
I did one with a formed brass plate (like a shelf) screwed into an underside pocket on the fingerboard extension, & attached the pickup to the plate with DC tape.
Milton, ON
PostPosted: Sun Oct 05, 2014 1:21 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Hey, Dave, do you have a photo of that--one that shows your mounting plate, etc.?
Patrick
PostPosted: Sun Oct 05, 2014 4:52 pm
State: Oregon
This pickup builder is a little closer to you. His pickups are of a very versitile dimension.
http://www.original-flatpup.com/index.php
PostPosted: Sun Oct 05, 2014 5:26 pm
Don't forget the Fishman Archtop Bridge with a transducer built into it. It gives a different sound than the humbucker.
http://www.fishman.com/products/filter/instrument:archtop-guitar/type:pickups
PostPosted: Sun Oct 05, 2014 5:32 pm
Jason, those flat pickups are wild looking. Have you ever heard one?
PostPosted: Sun Oct 05, 2014 5:42 pm
Hi Patrick
Here is the guitar
Milton, ON
PostPosted: Sun Oct 05, 2014 11:00 pm
State: Oregon
I've only recently learned of Flatpups from a friend, but have only seen/heard them on the youtube demos. Considering their size and construction, the sound quality is rather surprising. There is a discussion that I started on the MEF if folks want to know more about them, and the maker dropped in to talk shop.
BTW, this is a cool mounting solution, Dave.
